***PLEASE POST ALL BETA 13/13.1 BUGS HERE***
We're using a new version of VRay. I'll pass on your constructive criticism to Vlado. My first thoughts would be either our new default for noise threshold is too high (try setting it to 0.005 maybe) or are you using one of the new colormapping modes? I'll see if Corey or Vlado can provide more information on this.
As for your second problem. I'll check it out. Keep in mind that I don't see every problem that other people have on their machines. Otherwise these problems wouldn't exist. If you don't like being a beta tester then don't do it. Beta testing is for finding problems. If this beta is too terrible for you to use, don't use it.
[edit]
After reviewing your video. All of those problems are caused by some path problem looking for the little m buttons. The reason that exception happened was because you hadn't set a bitmap file before you hit update. I will fix this as soon as possible.
[edit]
