Archived Old Bugs
This topic is closed.
  • ***PLEASE POST ALL BETA 13/13.1 BUGS HERE***
    If I remember right, it is a very old bug: the rhino camera focal distance conection to the DOF settings dosn't work.
      Yeah thats fixed in my build
      Joe Bacigalupa
      Developer
      Chaos Group
      • Re: bad objects
        Originally posted by garrett_nmda
        There was one bad object, and it actually rendered fine in past renderings (a mattress). I removed it and I am still getting the crash.
        EDIT: Ok. Problem fixed. I deleted the objects and tried to render until I found the problem. FOr some reason a simple rectangle surface caused the problem. I turned it into a mesh and now all is well in the world.
        If you would still like to send me the scene I'll look at it to see if I can figure anything out.
        Joe Bacigalupa
        Developer
        Chaos Group
          Joe,
          I found the problem surface by a process of elimination. I converted it into a mesh. Now I can't recreate the problem, so there isn't a file to send.
          Thanks.
          Garrett
            Here a new bug: if I manipulate the spot hardness per spot light geometry, than the hardness will rendered like befor. But if I manipulate the hardness parameter, than the lightsource geometry and the rendering will be updated.
              When I attempt to render, it is also sticking on "Building static raycast accelerator"... the render progress does this very strange thing where there is a little what looks like noise in the lower left... unfortunately for me it never moves forward, its totally stuck.
              That and its a basic scene, never rendered in another build, single light, all white diffuse.
              Help?
                Hi
                Rectangle lights settings seem to reset every time I save, close and re-open a scene... What seems stranger is that it doesn't happen with any other light types.
                Anyone else having this problem?
                /BlueShift
                • Diffuse
                  Rhino seems to freeze when I update a material in the following way.
                  Set the difuse to a color, click on 'm', Set type to 'None' then click update. Rhino freezes.
                  • Re: Diffuse
                    Yeah I believe that has been resolved...for now just don't do that since there is nothing to update
                    Joe Bacigalupa
                    Developer
                    Chaos Group
                      Help?
                      Originally posted by SaadUrRahman
                      Hi
                      /BlueShift
                      These issues have all been resolved in the current build. A new release should be along shortly
                      Joe Bacigalupa
                      Developer
                      Chaos Group
                      • weird window problems
                        I have occasional weird window problems.
                        Sometimes when I minimze Rhino I can't double-click it on the taskbar to get it back. I have to right click, restore.
                        Other times when I have two instances of Rhino running, I render, work on the other instance and try to come back- same thing.
                        Not very important but it seems like an odd glitch.
                          Hi craiggorton
                          Same for me - but as you say not very important
                          • another not so important glitch
                            Along the same lines as other minor glitches, I have the Object Properties dialogue box docked to the right side of the Rhino Screen along with the Layers dialogue box. Sometimes after modifying the Mapping properties, I switch back to the Material properties and get this.
                            but when I resize the layers/obj. properties box (either one) it refreshes back to the normal view.
                            • mapping
                              I also notice that sometimes after modifying a material or object I select an object and the properties are toggled to "mapping" which I'm not even using yet.
                              • Re: mapping
                                strange, I'll see what I can find out about that
                                Joe Bacigalupa
                                Developer
                                Chaos Group
