Archived Old Bugs
This topic is closed.
  • ***PLEASE POST ALL BETA 13/13.1 BUGS HERE***
    Originally posted by joeb
    .... Should we take away the freedom of layering as you please and go back to a rigid 3 layer material? Diffuse - Reflection- Refraction and nothing else? ...
    Please no, I like the layer stuff. Looks fine for me. Also I would like to get a fresnel control to the main reflection options back.
      Originally posted by Thomas An.
      If we choose "renderWindow" the render never starts (it is stuck on raycast indefinately)
      Does this happen in any scene for you or is it one particular one? If it is just one particular scene could you send that along to me? Thanks
      Joe Bacigalupa
      Developer
      Chaos Group
        Help, the new beta 13 produce blury textures. Here two test with a 2d texture.
        Beta12.1
        Beta13.1
        Now I have a problem, in 5 days my beta 12 expire and than I must use the beta 13.
        Edit: If I enable/disable the antialiasing filter area 1.5, than I see no difference. Also I have tested different filters, but I get not the quality of the beta 12 rendering.
          ... if I "clear" an used texture, than the "M" stay instead the "m".
            Hi team,
            The multiplier number of rectangular light will back to the default setting (30) when open......
              How are you clearing a procedural texture? By setting it's type to "None"? Or do you mean clearing the file for the Bitmap Texture?
              Joe Bacigalupa
              Developer
              Chaos Group
                I have a scene which was started on beta12.1 ....
                ... now on 13.1 all lights are reset to default values every time the scene is loaded.
                (The lights are Rhino rectangular; they are not surfaces)
                Originally posted by cafer
                Hi team,
                Ok I'll take a look at that, thanks guys
                [edit]
                Ok, I found the problem. There was a screwup in the versioning of the rect light. It is fixed now, however, you will manually need to reset the values and re-save when our next build comes out. Sorry for the inconveniance, good catch!
                Joe
                Joe Bacigalupa
                Developer
                Chaos Group
                  Images Snipped...
                  Yes, Vlado said he had changed some things in regards to textures for this build. I will see if there is a way to combat this issue quickly.
                  Joe Bacigalupa
                  Developer
                  Chaos Group
                    Ok I just found what I think your talking about. If you clear the bitmap file and hit apply, it doesn't remove the Bitmap Texture. I just fixed that so it works that way now. Thanks
                    Joe Bacigalupa
                    Developer
                    Chaos Group
                      I mean, if I clear a bitmap texture. The problem seems to be, that the first m (for example at the diffuse layer) show a big "M", if "bitmap" type at the texture dialog is select independent from the usage of a bitmap. Maybe it could be useful to jump to texture type "none" if the user clear the bitmap texture.
                      • does 13.1 require SR5?
                        I have tried to uninstall v12.1 and install v13.1 and I'm not able to load the VRay plugin anymore ... it just gets an eror. Should I download the binary again, or am I missing something?
                        • Re: does 13.1 require SR5?
                          What error do you get?
                          Joe Bacigalupa
                          Developer
                          Chaos Group
                          • Crash
                            I am attempting a rendering which has not given me any problems before. I am not sure what I did today (some modelling) , but now it seems to get hung up on "creating rendering meshes" and never opens the VFB. After a few minutes of this, Rhino dissappears.
                              Try to do a check for bad objects, could very well be the problem. You say it hangs on render mesh, so probably it's not vray related.
                              • bad objects
                                There was one bad object, and it actually rendered fine in past renderings (a mattress). I removed it and I am still getting the crash.
                                EDIT: Ok. Problem fixed. I deleted the objects and tried to render until I found the problem. FOr some reason a simple rectangle surface caused the problem. I turned it into a mesh and now all is well in the world.
