Standard Light Projection Map
  • #31
    We're a few months down the road, and I'm hoping there's some update.
    • #32
      Pinging again, a month later.
      • #33
        Hey!
        This will be discussed with the team next week, it is still on the GPU roadmap with priority. Sorry this is taking time :/ ,It is that the devs has been busy with big features for a while now like texture compression(nearly finished) and kernel 3
        Best,
        Muhammed
        Muhammed Hamed
        V-Ray GPU product specialist
        chaos.com
        • #34
          HowardDay This is now in the nightly builds, being tested by our QAs as well
          Muhammed Hamed
          chaos.com
          • #35
            Thanks! Unfortunately, using June 2nd's nightly in Max 2022.3, rendering a spotlight with a projection map will randomly flicker in brightness on the GPU in RTX mode...
            Also visible on the spotlights of the main, center ship in this animation:
            ​https://drive.google.com/file/d/11Qd...ew?usp=sharing
            Thanks!
            • #36
              Isn't this intentional ? Your "SpotCookie" has two frames and the bitmap node is referencing them using an IFL file ?
              Greetings,
              Vladimir Nedev
              • #37
                Oh my god, you're right - that's exactly the problem. Sheesh, it must have auto generated the ifl because there were two images.
                Sorry to waste your time!
                • #38
                  And, nope, I was wrong. I double checked, and the lights in the ship scene are definitely using only the single PNG, not the IFL. And the flickering is random, per frame, per light. https://drive.google.com/file/d/11d2...ew?usp=sharing
                  So this is still a problem, unfortunately.
                  • #39
                    Thanks for the file
                    Our Developers are looking into this now, plus couple of other issues related to Omni and Directional lights
                    I will message here in couple days
                    Best,
                    Muhammed
                    Muhammed Hamed
                    chaos.com
                    • #40
                      is this not right to try projector maps for Vray GPU and Spot light? thanks
                      • #41
                        This should be supported now, we deployed more fixes to this. Please try with the latest stable build
                        Best,
                        Muhammed
                        Muhammed Hamed
                        chaos.com
                        • #42
                          drat. i probably lost access since the new IT people took over. I have update 1.2 (6.10.08 build 00000)
                          i'll see if i can get the u-name and p-word for management. and check to see if we have access to early releases?
                          **EDIT: I'm seeing Vray 6 update 2 available so will install and try it out. thanks.
