1.7 RC5
- Fixed slow interactive rendering response caused by the new direct light solver - we disable the adaptive learning when running IR
- Fixed occasional crashes in UHD cache generation - [https://forum.corona-renderer.com/ 3ds max region render crashes after a few frames #msg110442](https://forum.corona-renderer.com/ 3ds max region render crashes after a few frames #msg110442)
- Fixed occasional crashes when starting a second render - [https://forum.corona-renderer.com/ Daily Builds 1.7 #msg110682](https://forum.corona-renderer.com/ Daily Builds 1.7 #msg110682)
- Material Library - In another “there and back again” moment, MatLib has been renamed to Material Library
- Fixed popups caused by calling MaxScript functions not respecting 3ds Max quiet mode
- showBrowserIfPossible function modified to comply with MaxScript return value conventions (zero value means success, non-zero means error)
- Previews are now scaled with a better quality
- Added button for opening material browser to Scene tab in Render Setup.
- Added error dialogs showed in case Material Library is not installed or supported (sorry, we gave up on 3ds Max 2012).
- Fixed material tooltips not hiding
- Fixed “mental ray attributes missing” error messages on drag & drop - https://corona-renderer.com/bugs/view.php?id=2806
