3dsMAX default lights will render no REs
Sometime i need some lights with NO decay, so the to go lights are 3dsMAX defaults ones…
Main problem is Defaults 3dsMAX lights will not work with REs (no vrayspecular, no Vraylightening) and Vray lights do not have a no decay option (playing with decay settings do not really help there).
Bug or is there a workaround?
The standard light issue is a known one (check this thread). Otherwise, the No Decay option is still there, just not in the UI. You can control it through MaxScript by selecting a VRayLight and running this line in the Script Listener: $.noDecay = on/off
Thanks You so much, that’s exactly what i need…(please consider to re-expose the “no decay option” please)…
