I want to rotate my bitmap 90 degrees, how can I do that in Vray C4D?
I use nodal shading in C4D S24,
Something like this in Vray for Maya,
Same question on mapping type for an HDRI, in Vray’s DomeLight. Are there controls for flipping the map horizontally for example or for horizontal rotation
How do you do that in Vray C4D?
Best,
Muhammed
I’m afraid you can’t do that right now (I haven’t checked on latest build though). Normally you can do that by using the transform tool inside the C4D layer shader but last time I check it wasn’t working.
AFAIK your only options are to rotate the UV inside Cinema or the bitmap using PS.
Thanks Sirio76,
I’m on the latest stable build, rotating the UVs or the bitmap itself outside of Cinema are no options for me. I think I will wait
Maybe you can use the transform inside the layer and bake the results using the Vray baking shader. In past this worked for me for other unsupported shaders, you should give it a try;)
Thanks! will give this a try
