Built 5.00.42
I created 2 material with c4d noise in the bump channel.
if I apply one to an object, it works. If I use both with a blend material
the bump is gone.
Hi @folklore ,
thank you for the feedback. I’ve logged a bug for fixing and will update the thread as soon as it is fixed.
Hey @folklore
the issue with the Blend material and Cinema 4D noise is resolved and a build with the fix is available in our Stable folder on the nightlie builds server.
