Hi, when rendering frames in Houdini, Vray doesn’t respect the crop parameters on the camera node or it only works for the first frame of the render. Is there anything I am missing or is it a bug?
Using vray 6.20.23 Houdini 20.5.332 windows
Hi @mehdi_salehisaki Thank you for letting me know. I managed to reproduce the issue and will investigate further.
Seems to be working as expected in the latest nightly build. Could you please download and test it: link
Thank you @viktor_angelov …will try that and report back here
Hi @viktor_angelov , which version did you try? I can not see any nightly build for vray 6 Houdini
Hi @mehdi_salehisaki I tested with the latest V-Ray 7 nightly build and seemed to work as expected. If you do not have access to them I can requests it for you. Please, let me know.
Yes it seems I don’t have access. Can you please give me access @viktor_angelov ?
Please, give me the email address you want the access granted to. You do that here, via personal message or via a ticket in our system: Submit a request
It is vfxhomeland@gmail.com
thanks
Hi @mehdi_salehisaki you should have been provided with access. Please, let me know if everything goes as expected.
Thank you @viktor_angelov used the latest nightly and worked as expected. Thanks
Great to know @mehdi_salehisaki Thank you for sharing!
