When adding a default render settings LOP, my VRay render crops in slightly.
The houdiniGL, karma and redshift all match. It’s just VRay that is off.
https://www.dropbox.com/s/si1nb28o9pf6tgy/vray\_cameraCrop.hip?dl=0
I can’t work out what’s causing it… Is it a bug or user error?
Cheers,
David.
https://forums.chaos.com/forum/v-ray-for-houdini-forums/v-ray-for-houdini-problems/1134600-solaris-aspect-ratio-differs
We had some discussion here im trying to recall. If you change apsect ratio to crop aperture both karma and vray will match.
to be honest im not really sure what is going on and what is correct and not
@Gosho.Genchev maybe you could take a look
It’s because of “Expand Aperture”, I’ll try to fix this asap.
Should work in todays nightly, could you pls test?
Great just tested it, which seems to work, until I enable physical camera on my edit camera LOP it goes back to the original cropped in behaviour.
David.
Its seems to be ok with default settings but seems almost like reverse issue now.
If i change the aspect ratio vray starts to differ again with the opengl/karma render. Here you can see the opengl overlay over vray.
aspectratio_v2.zip (48.9 KB)
