Often times I find myself in a pickle. I am showing something but don’t have the time to walk there or “move fast” there. Move faster is too fast. Trying to give a good “walk through” but at a pace I want to set on my own. Is there a config I can change to make the SHIFT or CTRL move at a speed I pre-determine? If not is there another way I can do it? Or should I submit a feature request to have “move fast” and “move faster” be adjustable in settings by some sort of multiplier?
@arebe , right away, if you haven’t tried it already, you can also at least set the basic movement speed through the Renderer Window Settings:
This also has an effect on the SHIFT and CTRL movement speeds, but there is otherwise no way to adjust them individually.
Furthermore, just in case you weren’t aware, if you like to do a walkthrough that is a bit on the smoother side with some finer controls, you could also connect a controller to your machine and use it within Enscape - Click here to get some more info about the controls and mapping. Some prefer using a controller to navigate the scene, others do not. But it could be worth a try if you haven’t done so.
If none of the above meet your criteria, please do in fact submit your wishes directly to PM as well through our portal. Thank you very much!
Thank you, this worked. It is a little confusing how we have walking speeds and flying speeds that are different. But this solves my issue. Would be nice to customize each speed separately, thus 6 speeds:
Walk normal
Walk fast
Walk fastest
Fly normal
Fly fast
Fly fastest
… just a thought.
Feel free to also forward those thoughts through our portal of course if you like so that PM can see the demand for this.
