Increase Max Movement Speed
Could you please increase the camera movement speed max value. Sometimes I look at the building from far away and it takes too much tome to rotate around it. I know I can sync with Rhino camera, but it’s nicer to move in Enscape.
Thank you!
(You do know that you can double-click on something and ‘zoom’ to it… and that holding [shift] doubles your speed?)
I knew about the Shift but it’s not that ergonomic on the keyboard.
I think increasing max speed limit would be the best…
Like the “Movement speed” on the input tab of the settings?
@FloatingVolume what kind of Keyboard are you using? This is usually the standard key mapping in 3D Applications.
Pressing [STRG] or [CTRL] will increase the movement speed even further.
I’ve forwarded your request to our developers.
Hi Jonathan. I’m using a standard dell keyboard. Still, for me, even if I hold shift is too slow.
Thanks for forwarding.
And if you press the mentioned additional key [STRG]/[CTRL]? Still too slow? If yes you may have to check the scaling of your project as it may be too big.
I’m drawing several buildings and the scale in rhino is Large Objects - Millimeters.
If I’m pressing ctr+shift it works, but then I don’t have any hands left to use the mouse :expressionless:
(Use your piney finger on the left hand for the [shift/ctrl] press. It takes a little bit of practice, but you will get the hang of it.) Personally I would like a tab on the option screen that would allow you to re-map all the key strokes.
For navigation I would recommend getting a “3D space mouse” - very intuitive and a whole lot smoother.
