Chaos Corona 14 for 3ds Max - Previews (Daily Builds) Changelog
For all information about the Previews and the download link, see: Previews FAQ
This daily build will be released as Hotfix for Corona 13, if no issues are found.
Please test it and let us know.
Please check this article covering the risks of using daily builds: Daily Builds FAQ
If you are familiar with the daily builds and know how to use them, download the newest one from your MyChaos page.
Major User-Facing improvement
  • Added support for beta version of AI material generator. The generator can be found in Cosmos.
Bugfixes
  • Fixed issue where materials with textures plugged into roughness or IOR slots could be exported incorrectly into Vantage.
  • Fixed issue where firefly filter could create NaNs.
  • Fixed issue where outline was rendered incorrectly when using Camera with non-zero physical size.
  • Fixed slow uninstall stage of installer.
Preview build with many awaited features and fixes!
Test them as much as you can and share/report your findings in [Chaos Corona 14 - Previews Discussion.](https://forum.corona-renderer.com/ Chaos Corona 14 for 3ds Max - Previews (Daily Builds) Discussion )
Please check this article covering the risks of using previews (daily builds): Previews FAQ
If you are familiar with the previews (daily builds) and know how to use them, download the newest one from your MyChaos page.
Major User-Facing Improvements
  • Added possibility to render Gaussian splats using Corona Gaussian splats object.
  • CoronaPhysicalMtl rewritten to Qt.
  • CIE rewritten to Qt.
  • Added the option to dock VFB window. Dockable option can be found in zoom menu of VFB.
  • Added new Fabric material - users can control yarns, plies, fibers.
  • VFB - Removed confirmation dialog when enabling/disabling all lightmix layers.
  • Removed decimals from the (new) White Balance operator.
  • Improved viewport IR text during Vantage Live link.
  • Added new togglable “Collaboration” button to VFB ribbon, which shows/hides Collaboration on the left side, instead of a tab in the sidebar.
  • Added option to hide/disable AI features using CHAOS_DISABLE_GEN_AI environment variable. Setting it to “1” hides:
    • AI Material Generator from Cosmos
    • CMasking_AiEnhancer render element
    • Enhance button in VFB
    • Enhance button for VFB history items
  • Added new “Flip” toggle to the VFB’s Zoom menu, which flips currently shown image horizontally - shortcut ctrl + /.
  • Extended VFB title placeholder parameters with %cxr - this shows the path to the currently viewed cxr (VFB system settings).
  • Added option for CShading_Alpha render element to include bloom & glare effect.
  • Added checkbox for Corona proxy to play animation with FPS stored in the proxy file (previous behavior - default) or with the current scene FPS (similar to V-Ray proxy).
  • Changed default adaptivity interval to 1. Noise level can now be estimated after 2nd pass.
  • Significantly improved parsing speed, especially on CPUs with large number of threads. Geometry stage now stays consistent between renders.
  • Added support for randomization by pattern to Multimap and MappingRandomizer.
  • Improved the look of VFB2 tabs.
  • Rewritten the UI of ColorText to Qt.
  • Maps are reused and no longer duplicated when importing material from Cosmos.
  • Significantly improved volume rendering when volume is lit by polygonal light sources (no environment, sun).
  • Added automatic color space selection using OCIO rules when batch loading bitmaps from Corona MultiMap.
  • Added possibility to drag and drop multiple selected Cosmos materials into SME. The drop position of all imports even without drag and drop has slight shift applied to it.
  • Added upload conditions to the AI Enhancer button tooltip.
  • When LightMix element is displayed in VFB, it is uploaded to AI Enhancer instead of Beauty.
  • Added checkbox with simple triplanar mapping into CoronaBitmap.
  • Improved the import of materials from Cosmos: - Corrected the ordering of NormalTexture/MappingRandomizer/Bitmap
    • Fixed 0 scaling used in triplanar texture in AI material
    • Removed empty CoronaMix map plugged into SSS amount
    • Triplanar, MappingRandomizer map is reused if the same map is plugged into multiple nodes
  • Made UI more compact:
    • top toolbar’s height decreased from 56px to 40px (VFB1 had 28px)
    • tools sidebar’s width decreased from 342px to 300px (VFB1 had 240px)
Bugfixes
  • Fixed AI Enhancer image uploading cropped image when AI upscaling is on - now the whole image is uploaded in the original resolution.
  • Fixed artifacts created by slicer caps.
  • Fixed issue where IR would not update when an object with Corona Pattern modifier used option to use pattern material.
  • Fixed CoronaPatternMod incorrectly setting command mode to select (e.g. when cloning using Shift + Move).
  • Fixed issue where 3ds would get minimized after closing Corona Color Picker, Memory report dialog etc.
  • Fixed issue where Corona Pattern Mod could crash when using RaySwitch material or Light material on it.
  • Fixed “Rest” parameter in LightMix being reset when restarting rendering.
  • Fixed issue with wrong gamma mapping when importing normal map from Cosmos from Corona material library collection.
  • Fixed issue where triplanar mapping in Corona Scanned Material could rarely lead to NAN.
  • Fixed outline material when used with camera clipping.
  • Added night sky (moon and stars).
  • Rewritten to Qt: - CoronaLayeredMtl
    • CoronaVolumeMtl
    • CoronaHairMtl
    • CoronaSlicerMtl
  • Added the color correction options and tonemapping exclusion to Gaussian splats.
  • Added better flip frame options and crop box to Corona Gaussian splats.
  • FabricMtl - added option for normal/bump maps on top of the fabric mtl.
  • FabricMtl - Updated tooltip for distortion frequency and fibers frequency, to be less confusing.
  • Added non-physical control of reflection and refraction tint into Physical material.
    This helps to better convert V-Ray materials and import from Cosmos.
    These controls are hidden by default, located in material’s advanced settings.
  • ToonMtl - added shadow control & GI suppression.
  • Added option to invert the slicing to the Corona Slicer material.
  • Further improved volume sampling.
  • Added support for MultiTexture Map in Corona for Vantage.
  • Corona now automatically fixes NaNs/INFs found in geometry and reports them to users. This also avoids NaN related crashes.
  • VFB: - Moved Sidebar visibility button + Zoom dropdown to the right of the main toolbar.
    • Added option to VFB store images in half-resolution.
    • Updated icons, moved main tool buttons to left, added foldable icon labels.
Bugfixes
  • Fixed issue where accepting some confirmation dialogs could minimize 3ds Max.
  • Fixed freeze when changing post/lightmix settings.
  • Fixed inconsistent color space when doing conversion Bitmap ↔ CoronaBitmap where CoronaBitmap. Same color space as original bitmap is used now.
  • Fixed crash when converting Bitmap that is plugged into MultiMap.
  • Fixed issue where Gaussian splats could be rendered with unexpected hue shift.
  • Fixed issue where Corona Bitmaps No tiling mode did not work with Triplanar.
  • Added units to triplanar scale in CoronaBitmap.
  • Warning about legacy atmospheric elements now doesn’t appear when editing materials.
  • Fixed disabled instance randomization mode for MappingRandomizers imported from Cosmos.
  • Fixed NVIDIA denoiser not working during production rendering.
  • Fixed crash when moving the leftmost key in ramp using spinbox.
  • Fixed a crash in Save all in Corona Image Editor.
  • Fixed issue where some maps plugged into Fabric material did not have texture mapping coordinates remapped to [0,1] interval, which could lead to artifacts.
  • Fixed renderer change Yes/No dialog message box briefly minimizing the application.
  • Fixes the following issues with Gaussian splat object: - Crop box is wrong after loading a scene
    • Copying gaussian splats objects creates a broken copy
    • Curves can’t be turned off/on without opening the curves editor
  • Fixed crash with VFB docking into 3dsMax.
  • Fixed wrong SSS conversion from V-Ray material.
  • Fixed unwanted minimization of parent application (CIE or 3dsMax) when open file dialog is confirmed/closed.
  • Fixed wrong gamma when saving the image from CIE.
First Release Candidate of Corona 14.
  • VFB2 - Chaos Collaboration is now open in a separate dialog.
  • VFB2 - Renamed Collab → Collaboration, Enhance → AI Enhancer, made rounded edges on button highlights, increased button area size.
  • Moved moon glow parameter from sky map to moon.
  • Moon intensity multiplier split into two (visual and illumination) multipliers.
  • Daylight node for the moon can be selected in a viewport.
  • All scene cameras are now exported into Vantage.
  • Added new Defaults (reset) menu in Render Settings > System tab, moved “save defaults” into system tab.
  • Rewritten the UI of Corona Bitmap to Qt.
  • Scatter: - Ability to compute collisions between individual scatters: - Each scatter can be assigned to one collision avoidance group in the Scatter Lister.
    • Scatters in the same group don’t have collisions among themselves.
    • Collision evaluation is done based on priority - his priority can be also assigned in the Scatter Lister.
    • Object and spline lists allow adjustment of related properties in bulk when multiple items are selected.
    • Added addModelNode() command which can be used within scripts to add a model.
    • Added support for mesh objects as include/exclude modifiers.
Bugfixes
  • Fixed issue where outline disappears behind transparent object without outlines.
  • Moon brightness made independent of its size.
  • Sun and Moon are now always rendered behind clouds, regardless of cloud shadowing state.
  • Fixed crash when color mapping callback is called before VFB is created - or after it is destroyed.
  • Corona Image Editor: - Fix of slow startup.
    • Added missing UI update of progress bar during denoising.
    • Fixed not denoising an image due to wrong spp (samples per pixel) buffer.
    • Fixed proper cancelling of denoising when any other denoising mode is selected.
    • Store persistent settings of VFB for CIE in %localappdata%\CoronaRenderer\ImageEditor, instead of with binary.
  • Added UVMapper rotation parsing to VrMatConverter. Now W rotation is considered when importing from cosmos.
  • Fixed issue where stars would be seemingly bigger in reflection/refraction.
  • Normal map Red-Green flip is now imported correctly from Cosmos.
  • Added missing context (right-click) menu for the Daylight node in CoronaMoon.
  • Fixed inconsistency (not greying out) between bloom&glare and sharpen&blur when using camera postprocessing overrides.
  • Fixed exposure being incorrect when loading CXR in CIE (in history or opening).
  • Fixed issue where the Gaussians bounding box would get bigger than the crop box with increasing zoom level in the viewport.
  • Scatter: - Fixed parent window focus loss when picking colors for instance models with the Corona Color Picker.
    • Fixed issues with incorrect surface scattering on renderable and non-renderable shapes/splines.
Regression bugfixes
  • Fix of not stopping IR when closing dockable wrapper.
  • Fixing error estimate being zero in IR for first several passes when “IR subsampling” is used.
  • Spinboxes with world units now update on display units change.
Corona 14 Release Candidate 2.
  • Switched default preview mode of gaussian splats to point cloud.
  • Crop box of Gaussian splats is being shown and used instead of full bounding box for rotation, zoom extents etc.
  • Added “Fit crop box” button to Gaussian splat object, which automatically culls low opacity splats (performed by default).
  • Added (non-linear) sRGB color space option to Gaussian splats.
Bugfixes
  • Made VFB docking/undocking faster.
  • Fixed artifacts in Gaussian splats visible on geometry with shadow catcher material.
  • Removed duplicate stars, fixed moon disk size and gamma, removed fireflies from moon illumination, optimized star rendering and moon preprocessing.
  • Corona Image Editor: all settings now reset when Erase button is click.
  • Corona Image Editor - Fix of not visible changes after denoising mode is changed.
  • Fixed incorrect visibility of the sun/moon through clouds.
  • Fixed toolbar labels visibility when resizing docked VFB.
  • Fixed crash when sampling Anima materials.
  • Fix for Cosmos imports that use grayscale bitmaps and inverse in the output of a bitmap.
