Chaos Vantage v3.4.1 released
Hello everyone!
Hotfix 1 for Chaos Vantage 3, update 4 has just been released and here are the major changes:
Improvements
  • Improved the security of the Vantage application
Fixes
  • Fixed framing a selection or the scene with the Z or F shortcut changing the camera focus distance
  • Fixed Gaussian splats with the pivot at the bounding box center jumping to the center of the camera view instead of snapping to other objects when moved with the move gizmo’s center sphere
  • Fixed Basic meshes (except Disc and Plane) jumping to the center of the camera view when moved with the move gizmo’s center sphere
  • Fixed displaced meshes sharing the same mesh in an exported .vrscene file rendering with the same displacement texture, even when assigned different textures
  • Fixed the camera jumping far upward with collisions enabled when a basic mesh was below it
  • Fixed an invalid or missing output path not stopping the render, which lost all rendered frames
  • Fixed lines flashing in the physical sky when using Vantage in the SketchUp viewport
    and more…
You can find the full change log here:
Release notes
You can download the new version from here:
Download Vantage
The Chaos Vantage team​
