About as average as you can get. What can I do to make this look better? I thing I like the lighting and v-ray settings, but it looks to much like a cheaper render engine like Accurender.
Am far from the right person to give any advice but the image seems very dark. Could you beef up the general ambient light or increase the intensity of you light sources (or add invisible lights to the scene?)
I suppose this has partly to do with the generally dark materials in the scene. Is the ceiling supposed to be black-ish? Maby slightly brighter materials would get the light bouncing around the space a bit more?
tbny
pretty dark and dreary. any photoshop at all? If not, remember your work as a 3d artist doesn’t end after the render is done, its just the beginning. photoshop photoshop photoshop. ![]()
Church Lobby
I actually did do some post, but I’ll tweak some more.
A quick fix to brighten the image up in photoshop is to duplicate the layer and switch it to Screen as a Layer Type and then play with the opacity.
Church Lobby
I will try that. I am having the hardest time with those can lights. I tried everything and I just can’t get enough light out of them.
really? what kind of lights do you have in them? don’t be afraid to just use direction spot lights. I do all the time.
Hi, I’m new here and this is my first post so I don’t have anywhere near the knowledge of everyone else but how about a VRAY override material for the dark blue carpet as another idea. I often use this if I’ve got very dark flooring…
the man speaketh the truth…
Override material
Can you explain that more?
The man is a laydeee!!! ![]()
Hi Glorybound, yep no problem.
Take material already created for the carpet
Select VRAY override material from the material map browser
Keep old material as sub
In Gi Material, create a light grey material.
This will still give you the carpet as it is but it will reflect GI as a much lighter material.
If you put a VrayOverride material as your carpet then the color wouldn’t bleed onto the other materials making the room darker from the color of the carpet. Is this the correct explaination?
actually, apparently your a lil car and I’m a bunch of white boxes falling to the ground for no apparent reason at all. ![]()
basically yes. of course it all depends what color you use for your override material.
Those cans seem pretty small for the space. Yeah.. directional spots would help; usually it doesn’t have to be lit correctly, just as long as it looks correctly lit. Do those sconces throw any light into the scene?
Also.. that stair and railing…
@Sazzle74 - Nice to see another Manc on the forum! ![]()
Is this not just lacking gamma correction? Are you working to LWF?
The image looks like the lights are all off. It looks like you could do with some chamfers on edges as well to catch some highlights, I agree with previous post mentioning using max spots as well.
Why thank you ![]()
You’ll be sat under the same grey sky as me right now then!
I think is a combinations of a little bit of everything…bad illuminations and materials…use Vray override material for carpet and ceiling, a little bit of ambiental light would be good, decrease displacement, the light blue leather is too glossy, it looks like plastic or metal.
those 3d people work fine when they are a little bit further from the camera, in this shot I’d use cutouts.
@ sazzle74 - Just escaped back to sunny Bolton… :lol:
Bobby,
Yeah needs a bit of work. Either in vray or PS.
He is a quick tweak I did…curves,shadow/highlight,exposure.
