When rendering animation and Clear VFB inbetween renders is unchecked, rendered images in vfb are stacked ontop each other. On single frame render it acts as supposed to.
It’s not a bug
When you run animation with low numbers of passes (as 20 for example) then so little passes is not enough to erase the last image.
Just check on “Clear VFB inbetween renders” and have fun (;
ps: Sorry. Was mistaken. Even for 100 passes I get the something like as MB ((
And images look normal when just run separately two different frames one after another. Troubles just with animation
Is there some explanation why is my VFB looking like this? It looks different than all the other VFB windows I have seen… I have corona alpha6, 3ds max design 2013 and windows 7
Yes, there is. “i have corona alpha6” - that’s your answer. Download and install latest public build A7.2 and you’ll have same VFB like everybody else.
Yes I was afraid to get that answer.. But i have been watching tutorials using alpha 6 and it looks exactly the same as alpha 7.1 vfb without the colormap tab… Ps I had alpha 7.1 but I downgraded it to alpha 6 because of the timelock (31.12.2014).. And alpha 7.2 is working only untill end of february.. And I cant afford the corona render 1.0.. sorry that I hijacked here
