VFB clears when it should not
Hello everybody,
My VFB clears when it should not, (at least I think so)
Video demonstration: https://youtu.be/MqoF6cowJ08
  • Clear VFB inbetween renders is checked off
  • UHD is secondary solver
  • VFB still clears if I render different region
  • works fine if pathtracing is selected as secondary solver
System:
Corona 5 RC2
Cinema 4D R21
Mac Os Catalina 10.15.1
Cheers,
Daniel
Hi Daniel,
Thanks for letting us know. We will look into this.
A workaround, for now, would be to uncheck “previz”.
This solves it,
thanks.
Also, the latest RC (RC 3) should solve this too, now that it is out :smiley:
Hi Daniel, Please test again with V5 RC3. I just did and it seems to be working for me. If you can confirm, that would be great! Thx
Hi beanvizion, I can confirm it keeps previous information in VFB. Other Bug that was reported has also been fixed, thanks a lot: https://forum.corona-renderer.com/ STATS Tab not displaying information on VFB - Cinema R21 Corona 5 RC2 - Mac #msg159764
However I still cannot delete individual snapshots (depicted in the link) in history tap, only delete all of them, and the info text is not clearly visible.
Thanks for confirming the other issues. We will investigate this current one and update you asap.
(Internal ID=428318870)
Thanks for an excellent customer service.
Hi Daniel, Is this issue still happening in the official V5 release? If so, can you also tell me the OS you are running?
Hi, I use Mac Os Catalina, still cannot delete saved VFB individually in v5 official release
Hi Daniel, If you haven’t done so already, could you please test the “cut off” UI issue with the latest release V5 HF2 and let us know the outcome?
Hello Beanzvision,
in HF2 still cannot delete individual saved frames in VFB. If you were referring to this issue:
https://forum.corona-renderer.com/ Render Region VFB Shift Bug #msg162140
It still exists in HF2 as well.
Daniel
