Corona for Cinema 4D Beta 1 daily build
Hi all,
We are releasing first daily build of Corona for Cinema 4D Beta 1. This is a daily build so some parts of the plugin are not finished yet, it can be unstable and there is probably a lot of bugs. Update to the new core and complete UI review and rework took much more time than we expected but we would like to show you that development of the plugin keeps going. The work on interactive rewrite is still in progress thus it is not part of this daily build, but there are plenty of other changes, here is the list:
Update to new Corona core (1.6 daily build).
Completly reviewed and improved all parts of UI:
Corona menu: reorganizations.
Render settings: light material can be used as environment map now, primary and secondary solver settings replaced with GI mode.
Preferences: moved VFB settings from render settings, added new configurations.
Picture Viewer: added buttons for saving and resuming the render to/from exr file (also in VFB)
Materials: removed brightness, added level, other changes.
Tags: improved UI of compositing tag.
Other changes:
Automatic conversion of Cinema4D materials to Corona materials before render.
Added missing multipass elements (virtual beauty, bloom and glare etc).
Added missing features to Corona Output Shader
Added Corona ColorMix shader
Added more controls to postprocessing panel.
Added new icons.
Improvements in preview rendering.
Improved multipass dialog.
Improved synchronization of values with postprocessing panel.
macOS installer detects also Cinema Demo now.
Changes from A6.1: fixed conflicts between Corona for C4D and V-Ray for C4D plugins.
Changes from A6.2: fixed “Shaking camera” bug, problems with artifacts in displacement, resuming of rendering in Corona VFB when using the scene with UHD cache enabled.
Changes from A6.3: fixed problems with normal map strength settings, problems with normal maps when projection other than UVW mapping was used and various other issues connected to normals, not working motion blur when command line render is used and crashing of Corona when displacement was used mainly for bigger scenes.
Download link:
https://drive.google.com/drive/folders/0B7xyYS3daSJ7V3BJZWlMR2EzUG8
Nice :smiley:
tho folder seems to be empty, maybe am too early - will check again later
Some compilation problems with older versions (again) :wink:
Good work guys !
Thanks. What about the activation of the beta? Need to buy a licence?
Installation for Mac does not work. Tried with R16 and R18. Once I open Cinema, Corona is nowhere to be found. Have not tested PC version.
I can confirm installation for MacOs does not work?
Just wanted to say that the Bitdefender AV Free Edition reports the installer .exe to be “bad” so a user has to unblock it :smiley: Excited about the release, good job team!
edit: Better yet, it blocks the .exe in the middle of the installation lol
I hope the asking for a license and refusing to work has nothing to do with today’s date, April 1st.
Rephrasing: Has anybody managed to get beta 1 running? If yes, how? Does it require a beta license and if yes, how to get one - and if no - why do I get this message? Is there any workaround? Should it work “as is”?
CU
Michael on Win 10 / C4D R18.
just had a chance for a quick look and it’s working fine here on win 10, C4D 18.041.
You could try removing corona from the plugins folder and sometimes there used to be a few files floating round in the main C4D folder but not sure if there still are - then reinstalling?
No chance so far unfortunately. Thx for your help.
Same problem. I’ve tried uninstalling all, delete appdata and clean the registry. Nothing to do.
Know, this is a daily.
… If you want to test daily builds to help us with betatesting please send your email address to tomsu@corona-renderer.com.
-source-
Since Alpha times :smiley:
Thx for your information.
Well, Beta 1 was due for Q1, which officially ended with March 31, so a public download here was expected and prone to cause confusion the way it happened, especially since there were no “daily alphas” here I was aware of.
I’ll send the corona team my email address and see how it goes.
So, thx again.
CU
Michael
Just installed beta 1 (upgraded from A6.3) but crashes on render. No bug reports are generated. Running Windows 10 and C4D R16.050
*Update. I uninstalled beta 1 and reinstalled A6.3, even rendering a basic cube crashes my Cinema now.
Hi, can you please send a list of paths where you have installed all versions of Cinema4D. I changed detection of installation paths that installer can find the demos too, but there can be some bug.
Hi, thank you for the message. We will report false positive to Bitdefender.
Hi Team,
The installation work well for me, Win10, R18.041.
The hdri dont work.
  • create a sky object, add a material with hdri in diffuse, crash without rapport.
  • Scene environnement, override c4d environnement with a hdri in diffuse, crash
Lightmix
-scene with a sky and sun, add a corona light, multipass, enable, ligthmix, light select, add the corona light. VFB, hit render, ligthmix, play with value and nothing change.
Hi, I tried a fresh install of beta 1 and there’s no crash or hangup when I render a simple scene. It must be something in the materials or in the scene that you are trying out. Could you send us the scene please?
