Corona Mesh Export
Hi everyone. Here is “Corona Mesh Export” macroscript (Vray Mesh Export analog).
Install it by drag and drop in MAX window.
Select one or several objects then start macroscript via quad menu.
corona_proxy.ms (2.61 KB)
Oh yeah… Just what I was hoping for corona to have.. Thank you! I will give it a try very soon hopefully :smiley:
Very nice indeed .. but what about material handling ?
I ask that because I can’t test myself .. still unable to run Corona on my workstation :frowning: :frowning: :frowning:
Great add thanks a lot !
All materials are copied from parent object to child proxy.
Nice !
Thank but is it possible to add the option to export and animation in Proxy? Cause I would like to create a forest with wind and animated proxy is the unique way to do that. Thank
I think there is a problems in the export directory.
If I select a directory, the proxy is created not inside this directory, but outside.
And the *.cbin file has as a suffix the name of this directory. Very odd…
UP!
have you tried recently? I did some changes
wow! thanks man!! its so useful!
this thing is amazing
i like it a lot lot lot more then vray mesh export
i mean my full of geometry and foliage scene got converted in 2k poly LOL
just a bug though it does not make the proxy in the folder you specify .. it create them outside it :smiley:
i just create 2 folders :tongue:
Is it possible to make it export few meshes in one time?
Yes, just select several meshes before lunching script.
Wow! Thank You so much! Didn’t thought it’s so simple. :smiley:
it works .. woww.. thanks bro ^^ . but, just problem with path, it cannot into the folder we want .. but its oke, still amazing ^^
Is it me or the plugin doesnt remember the last settings used?? can it be changed?? Great adition THX
Slap me silly … but what is this for?
thanks.
Proxy
It needs to upgrade, cause an error in the export directory. :wink:
