I just found that it works in new scenes, but doesn’t work in the legacy ones, at least not in the one i attached here. After reseting render settings, layered displacement starts working here too. Maybe i did mess up with render settings somehow, but i couldn’t find anything that could be causing such behaviour. I would appreciate if you could take a look and let me know what’s wrong with this scene. layered displacement issue.7z (70.9 KB)
Thank you Romullus, it seems that’s a bug with the Displacement preservation in Mtl override, displacement won’t be calculated/rendered. So to resolve it remove the preserve option, I am reporting it, thanks again.
We can’t even hazard a guess yet, since a major feature (tone mapping) is not even in a daily yet So that has to be in a daily, then it depends on bug reports or user feedback, then we will have a better idea of how much is still to be done before things could move to RC stage - but until then, who knows what bugs and user feedback there could be… maybe none all is perfect, maybe lots…
highly recommend adding an option noise amount, pass amount and denoiser amount in Corona Camera to be able to adjust theses parameters per Camera view/
for for huge render time savings per camera/because each view sometimes requires visually less or more noise amount or passes which theoretically can greatly reduce render times.
can also dramatically reduce render times at different resolutions on different cameras
I once wrote about this also in future requests but got no answer
thanks
Thanks for the reply. I sent you the scene “Trees and Grass” I hope it will help you. But I still recommend making the “Convert to PhysicalMtl” parameter and leaving Legacy Material as the default. Since at this stage, if there is an incorrect conversion from Legacy to Physical, then I have uncertainty that it will also not correctly convert VRayMtl in places, until the system is 100% debugged, it is still worth making the life of users easier. I have now almost stopped using the converter, due to incompatibility with previous versions of Corona and a certain lottery when I am not sure of the exact result.
Another example of a complex scene in terms of materials. After the conversion, you will have to edit all the materials, since there is not a single hit. My cannon is bronze, the converter says it’s not metal, but how does the system know where the metal is, where it’s not metal, at the moment it can only be determined by a person. Different behavior of Glossiness and reflections. As a result, you need to tweak and optimize everything. With this quality and accuracy of the conversion, the question arises, and will it also work with Vray? Converting to physical material is a point function, but not as global as it is now.
God forbid if you release this converter to the masses like this, even with all the fixes, but I’m sure there will be a lot of headaches for people, many will not appreciate it.
Thank you for sending over a scene, our devs are looking into the conversion right now and they will see if something can be done.
To answer this point, unfortunately in Corona we do not support forwards compatibility. So in the past this situation might have worked, it also might not have worked and caused some unexpected behavior and crashes.
and about the converter?.. falloff maps still being a mess when we use the last converter. The converter create a lot of CoronaMix maps. Thanks for your hard word, I believe that issues will be fixed soon!
If you have a scene where the conversion doesn’t work correctly please can you send it to us and we will investigate. Instructions on how to send the scene to us can be found in my signature.
Anyone having issues with the color selector? Whenever I try to pick a color, my CPU gets crazy maxing out all cores, and it stays for 5-10 seconds; it’s unusable.
Hi guys, i just start trying Corona 7 last daily. One thing i have noticed is that in some models specifically on archmodels collection 171, when converting from CoronaLegacyMtl to the new CoronaPhysical material i have an issue with the refraction. For some reason the guy that made the models had the refraction level 1 but the color black so even if in the legacy material that’s not a problem and won’t translate as glass, after the conversion to physical material it is a problem since the leaf looks like glass. As far as I can understand in the conversion takes into account only the refraction amount and not the legacy material refraction color. I hope that makes sense!
