Hi Guys,
When using Corona Sky with the VOLUME EFFECT ON, a glitch occurs in which a white background appears from around 60% of the image height. It cannot be overridden with the SCENE ENVIRONEMT option.
Did anyone else have the same problem?
Thank you for any reply.
Do you have clouds enabled in Corona sky? It is known issue that those two can’t work together, you have to choose either one or another.
Ohhh…OK…thanks. I have it active. I will deactivate the clouds.
We are aware of this. Hopefully will be fixed soon.
(Report ID=CMAX-821)
