Is there a one click or roughly one click solution to convert Corona scenes to Vray? I realize I will have to do some manual work but the default Vray scene converter errors on Corona Materials.
What kind of error do you get? Can you paste it here? Also, which Corona version, and which 3ds Max version?
Ok, we already have a fixed script for this, you can email me to vlado@chaosgroup.com and I can send it to you.
Thanks. I sent you an email with “Message Board - Corona to Vray” in the subject line.
Vlado can you please post the script here ? Or it is distributed by mail only ? ![]()
Yep, I will post it a bit later today.
Hello, just for completeness here is the script with this problem fixed. It would also become available in the nightly builds as of tomorrow.
Alexander
vrayutils.zip (21.9 KB)
Hi Alexander,
Just tried the latest nightly with the converter
It seems to work but there are some things that are not converted, mainly the CoronaLayeredMtl and the CoronaMix
Here is a printscreen of a scene converted and listed in Zorb :
Only a fraction of the scene renders not black as the major once used are layered.
Look forward for a update to this converter as it will make it so easy to switch to vray from corona.
Stan
