Hi all -
Having a problem pop up with displacement - pls have a look at the attached thumbnail.
The only thing that should be displaced is the type, but I"m getting artifacts below it no matter what I do. It had been working fine on this model, and I do not think it’s the map as I have remade it several times now. I’m using the modifier, 2D, placing the map with the Vray Bitmapfilter, and it’s a 16bit image. If I turn the bottle slightly this seems to disappear, but I need the bottle straight on. I have also tried upping the smoothing and turbosmoothing but it didn’t make a difference. Very odd.
Thanks for the tip. I am not sure what it means, but I’ll dig around and find out. Incidentally, 3D displacement seems to fix it too, but it’s slower for sure.
I had to switch back to using the Max bitmap loader to try it, but the result was the same.
I ran some renders overnight using 3D displacement and that worked fine though. Is it normal to have only one disp. mode work, as opposed to just work “better”? I have never really been clear on what the difference is, I just think of 2D as faster and 3D as better - but it’s pretty fuzzy beyond that.
