I’m not sure if this is something wrong or if i’m doing something wrong.
I have a model from mudbox lowest level, i’m trying to subdivide it to smooth it out a little. Because it’s the lowest level it has kind of jagged looking faces. My displacement looks great on it, but it’s on those jagged faces. But if I add subdivision to the model it appears to smooth out the displacement, pretty much removing it. Is this how it’s supposed to work? I’m using Vray next.
Setting subdivision and displacement bounds to explicit allows me to see it but just barely peaking through the subdivision. At least I know it’s actually there. But how can I get it to look the way it’s supposed to though?
Displacement isn’t as straight forward as you would expect. Did you export a 32 bit tif or exr for your displacement? Do you use udim tiles or a single tile? did you set your clipping boundaries? Is your scale the same between mudbox and maya? did you allow negative texture color in your file node?
No one else has run into this? Is displacement supposed to work fine on SUBD surfaces? I’m going to have to use redshift if I can’t get this to work in vray and i’d much rather use Vray!
This seems like this problem could be fixed if there was a way to allow the min and max settings to be set to negative numbers? Instead of color selectors. Unless I just don’t know the proper way to do it. He’s using a multiply devide to “fool” the min max to go into the negative
