hi, is this enscape related?
@FloatingVolume , thanks for your report - do you experience any problems with Enscape in general, or are you just getting these error messages? If you could send in a dedicated feedback report should you have any issues with Enscape, then that would be very helpful for troubleshooting purposes. ![]()
I’m getting this error messages when enscape is running. the strange thing is that sometimes i get them even when i close enscape.
A feedback report could help with identifying the cause behind this, although if you don’t experience any problems maybe you could ignore it? Also, a clean re-install of Enscape may help as well, just in case you want to try that out. ![]()
I do experience problems because usually i close enscape to be able to model fast. while this problem occurs when i change geometry. also camera movement gets slowed down. I’ll try to understand better in which occasions it occurs.
In this case a feedback report would indeed be great if you could submit one!
