Do we have a memory leak or??
So I am trying to render a set of frames and it will crash with a (700) error which from what I understand this may be a memory issue. I have occ turned on atm
This is a pretty big sim using RTX to render by the way
Houdini 20.0.590
Vray 2.2
Frame 1
[11:12:29.326] Peak memory for “Misc.”: 9.72 GiB
Frame 16
[11:26:04.663] Peak memory for “Misc.”: 15.30 GiB
I did run about 100 frames last night and peak memory was like 100gig​
More info
Could not allocate 6990500 bytes of GPU memory
30636: Fatal error: Segmentation fault
FromVFB Below
[VUtils::VOptix::OptixPipelineWrapper::launch] 7900: OptiX error encountered in vray_optix7.cpp[319]. Error Code 7900
[14:58:07.330] Error : [VUtils::VOptix::OptixPipelineWrapper::launch] 7900: OptiX error encountered in vray_optix7.cpp[319]. Error Code 7900
[14:58:07.332] Error : C:\CI\cgrepo\vraysdk\samples\vray_plugins\rt_priva te\rt_opencl_(3488) : CUDA error 700​
Dear @mike_jag , hello.
Thank you for contacting us.
Please share with us the exact V-Ray version used (V-Ray > About V-Ray > Copy to Clipboard and paste here).
In addition please confirm also the installed GPU driver version. The recommended one could be found on this official page: V-Ray GPU | GPU rendering by Chaos
We have encountered something similar in other V-Ray integrations, but without the exact V-Ray version is hard to match.
Waiting for your answer.
TS
Here is the info, Sorry for the delay
This is happening on 3 different systems by the way. All but one have the recommended driver with the same version of Vray as well as Houdini.
V-Ray for Houdini hash:82c1b12 from 19 Feb 2024 11:02
V-Ray Core 6.20.05 [31923cf8] from 17 Feb 2024​
Thank you for the details.
Please try rendering the same scene with our latest stable builds, available here: Chaos
Certain improvements are implemented there.
If you are still experiencing this, please provide us with a test scene to perform actions in our environment with it.
Thanks in advance.
Thank you, I will try that today. Hopefully, this will fix the issue
