Enscape 4.17.0 Released
Dear Forum Community,
We’ve just released our latest version Enscape 4.17.0!
Improvements- DLSS: DLSS version 310.5 update. Includes bugfixes and stability improvements.
  • Light Management: Improved light clustering behavior in orthographic view, ensuring lights group and separate more predictably when zooming and navigating the scene.
  • Visual Settings: Presets panel is now expanded by default.
  • Archicad: Improved all-user installation support, as we’re now registering Enscape in the AddOns folder. Windows users created after Enscape installation will also have it installed.
Fixed Bugs- Cloud Licensing: Fixed Cloud licensing reliability in secured corporate networks, reducing connection issues when obtaining a license.
  • SketchUp: Fixed an issue where Enscape would temporarily show duplicates of entities that didn’t actually exist.
  • SketchUp: Fixed a case where wrong textures were shown with materials upgraded from SketchUp 2024 to 2025 and newer.
  • View Management: Allow for the update of the name to be properly executed before we save.
  • Light Management: Fixed selection sync issue when deleting selected lights from CAD.
  • Renderer: Fixed a very rare freeze when opening another Enscape window while the main Enscape window is loading.
  • Renderer: Reduced aggressive Level of detail for smaller globe plant assets.
  • Renderer: Level of detail of assets was rendered incorrectly when using an orthographic camera projection.
  • Renderer: Fixed grass disappearing while still being in viewport.
  • Renderer: Missing grass in captures in case multiple, large surfaces with grass material were stacked on top of each other.
  • Renderer: Fixed light reflection visibility not handling clearcoat materials.
  • Renderer: Fixed an issue where the sky can appear pixelated in video previews and exports.
  • Renderer: Fixed disappearing Billboard geometry when camera moved very close.
  • Asset Library: Improved performance when placing assets in old asset placement modes.
  • Material Editor: Fixed feedback button in the AI Material Generator not working.
  • V-Ray Scene Export: Enscape produced large V-Ray scene files due to duplicating the geometry of asset instances.
  • V-Ray Scene Export: Fixed Scene Export sometimes crashing.
  • Batch Rendering: Fixed a crash when canceling batch rendering while light management is active.
  • Enscape Impact: Energy performance results are displayed properly when Impact is reopened after a successful analysis run.
  • Enscape Impact: Fixed: Impact Report data are invalid in imperial units.
  • Licensing: Updated License overlays for Error -200.
Known Issues- Batch Rendering: Enscape may crash when canceling batch rendering while light management is active.
  • Vectorworks: A problem where self-referencing design layers are not rendering assets.
  • Asset Library: Enscape could freeze when repeatedly pressing the Asset Library hotkey.
  • Light Management - Archicad: In Archicad, changing a light name will not update it in the Light Management window. On restart of Enscape, the new name will be shown.
If any questions or further feedback arises, kindly let us know via this thread or by reaching out to support. In case your experience any crashes, freezes or similar, please submit a feedback report with log files directly.
Do you generally test the installer of new versions of your product on clean systems or at least on virtual machines (to simulate a clean, newly installed Windows)???
For several versions in a row, the Enscape installer has been doing its job poorly!
After installing Enscape, you need to manually launch Chaos services.
This has never happened before!
Why did you mess up the Enscape installer?!
