Hello, I downloaded normally but when I go to install it gives an error and I can’t progress.
the file is attached
Eu baixei, porém quando clico nem abre o instalador.
I solved by installing the preview version
Enscape™ - Pré-visualização Enscape (enscape3d.com)
I am sorry to hear that - Does this issue still persist? If so, can you also try to run the installer through an administrator account? It seems you are simply missing write-rights when it comes to our .MSI installer.
Hello, my account is an administrator and I also tried to manually give permission to the file and it didn’t work.
This is very specific with this version.
because I tried the preview and previous version I had no problem.
Porque não estou consigo fazer a instalação da versão 3.3?
Eu baixo na seção de downloads, clico no instalador e não abre, já tentei reiniciar o computador e nada.
Alguma sugestão?
Thanks for the reply/report.
Could you kindly try to acquire and execute the following installer too:
https://enscape3d.com/download/
It should make no difference compared to the one we published on the Portuguese site, but just to make sure it isn’t caused by a faulty installer on that particular download page.
I’ve also contacted our developers to have a look into this - Is there perhaps any chance whatsoever you are able to change your system language to English temporarily? It should not make a difference, but it is a weird coincidence that it seems to only occur on systems where the OS language is set to Portuguese. Let me know and thank you again in advance.
