error: UNHANDLED EXCEPTION: Rendering frame
Hi
I got this messages today ( yesterday there was no problem) using VFB but when rendering with the MAX Frame Buffer - it renders OK.
[2009/Apr/13|13:54:08] Broadcasting NOTIFY_PRE_RENDERFRAME.
[2009/Apr/13|13:54:08] beginFrame() done.
[2009/Apr/13|13:54:08] Broadcasting NOTIFY_BEGIN_RENDERING_ACTUAL_FRAME.
[2009/Apr/13|13:54:08] Setting up DoneCallback.
[2009/Apr/13|13:54:08] Rendering frame region (2533,1454)-(2533,1454).
[2009/Apr/13|13:54:08] Photon size is 56 bytes.
[2009/Apr/13|13:54:08] Light cache sample size is 120 bytes.
[2009/Apr/13|13:54:08] Building light cache.
[2009/Apr/13|13:54:08] Tracing 0 image samples for light cache in 4 passes.
[2009/Apr/13|13:54:08] error: UNHANDLED EXCEPTION: Rendering frame
Last marker is at .\src\globillummap.cpp, line 1394: GlobalIllumMap::buildLightMap() {2.1}
[2009/Apr/13|13:54:20] Scene transferred to slave1…
SP3 one client + 3d hosts using LWF.
Which V-Ray version is that?
As mentioned in the previous post: SP3 (actually SP3a) employing one client + 3 hosts.
NIR
It says “Rendering frame region (2533,1454)-(2533,1454)”, which is in fact empty. Do you have the render region button on in the V-Ray VFB?
I cant recall but it was happening in full frame as well (almost 100% sure)
Nir
Well, that’s the reason for the crash; why the rendering region is of zero size am not sure. If you wish, you can send me the scene to vlado@chaosgroup.com to take a look.
Vlado the scene is on its way
NIR
Hi Vlado,
Did you find the solution to this? I’m having the same problem.
When I turn region render off it works fine. Also renders fine with Max’s frame buffer.
I’m using SP4.
I’m not sure if this is important, but I’m using clipping planes with a vraycamera.
Thanks.
The same happens without clipping.
