Good morning I need help I have a scene with reflective materials metal and glass and where the reflection there is a very large flicker how can I solve
Thank you!!!
Hi, are you able to share the scene with us so we can take a closer look? If so, please use the private uploader here: Chaos
the scene is attached above
The scene, as in the C4D file - not the mp4 render, which is the animation
You can use the private uploader to send in the scene.
i suspect those are either sun, point light or some other high intensity emission body highlights (HDRI?)
so try
- lower material reflection (glossiness and/or color…) aka make shader a bit darker and rougher (cuz no material is pure 100% reflective and white in color)
- obscure, diffuse, blur the emitter
- clamp highlights
