help with proxies!
Hi all,
I’m testing the new Corona 1.001
I did a clean installation deleting the previous version (alpha 6) within the 1.0 installer.
I opened an old scene with a lot of vegetation created with Forest Pack Pro.
Last year I created all my Corona proxies via the Vrayproxy converter script.
Now in all my scenes all proxies are disappeared!
What can I do?
selecting a CoronaProxy I read: (ERROR) Cannot parse file ‘my path…\myproxy.cbin’
It seems that Corona can’t read the old cbin file structure
please help.
regards
have u looked if the path for the proxys is the right one?? Perhaps u have to update the proxypath!
yes,
Corona 1.001 tries to read the proxy files, the path is ok but the cbin files are not recognized.
Hi all,
is there a way to convert a mrProxy to Cproxy?
Thanks for your help
regards
Thank you said much Rawalanche.
I’ve got this exact same problem! Proxies made with V6 Corona can’t be loaded with 1.001. I get the same error message ‘(ERROR) Cannot parse file’.
The network paths are all correct… Any help please.
Any one? I need help on this asap please :smiley:
Have you tried the BATCH CONVERT option?
What does batch convert do please?
Look at the “tool tip”, I guess this is what you need.
I’ve had a play around with the Batch Convert and it constantly says ‘successfully resaved 0 proxies’. I have tried the folder with the max files in and the separate folder with the proxies in… Any ideas?
Anyone?
Hi, could you submit a new support ticket with a good description of your problem? (if you haven’t done that already) https://coronarenderer.freshdesk.com/support/tickets/new - this will be the most convenient way to find a solution.
Ticket submitted
Got a huge scene with lots of vray proxies that I need converted. Also tried the Batch Proxy button, but same result as MGDesignUK: “successfully resaved 0 proxies”. Did you find a solution to this?
3ds max 2020, latest offical release of corona.
Try to run 3ds max as admin, and make sure what you have permission to folder (not on C disk), i have the same problem some time ago, maybe script can’t save files because of permission
