libreria de activos
Buenos días al querer abrir los objetos me emerge un cartel indicando que no tengo conexión a internet, me sucede con skp y con Revit, también con la versión de prueba , puede ser algún cortafuego o config ya que tengo intenet estable .
@nicolascalveyra , can you please try again? If it still doesn’t work afterward, and you’re not connected to a proxy server, another possibility is that your firewall is blocking Enscape from connecting to our Asset Library server. Please set the following URL exceptions, that are for connection to the Enscape Asset Library, Web Standalone, Panoramas, and Feedback services, to listen on port ‘443‘ with protocol set to TCP (http and https):
https://api2.enscape3d.com
https://asset-assetbucket-1binh6y04tlmk.s3.eu-central-1.amazonaws.com
https://feedback-feedbackbucket-kqjsgygrcfpd.s3.eu-central-1.amazonaws.com
https://panorama-panoramabucket-17m6l0kcpd6x2.s3.eu-central-1.amazonaws.com
https://enscape-mobile-runtime.s3.eu-central-1.amazonaws.com
https://webstandalone-raws3-p2dyeqrxcbok.s3.eu-central-1.amazonaws.com
https://webstandalone-bundles3-17tmvx8yf2hr9.s3.eu-central-1.amazonaws.com
Please contact us if the issue continues to persist!
