Lighting Issues
Latest update installed, but cannot get any lighting to show up. Everything is on in Revit, and with the exception of the lights (fixtures and light sources), everything is represented in Enscape. When the artificial light option in settings is turned all the way up, you can vaguely see small pin pricks of light. Even the moon and stars (which are turned on) do not appear.
@Jace , thank you very much for your submission. Sorry to hear about this problem.
We have not received any reports about such behavior before, so could you kindly send in some feedback as described here, and also send us the project? If it’s confidential, you can send me the download link via PM.
Also, could you kindly share some screenshots of this behavior as well, for example, one image where the lights are visible, and another where they are displayed as “pin pricks”?
Finally, was this problem not occurring before you’ve updated to our latest release? Does it occur when using our preview?
That would be very helpful to further troubleshoot the cause behind this. :slight_smile:
