No Artificial Lighting visible
Hy guys,
We’re testing Enscape, and really like what we’ve seen so far, but have an issue. In our models none of the artificial lighting is visible. The families can be seen in the model, but they do not cast light in Enscape. The IES Gallery example file works fine, however copying this content into our standard template, the artificial lights don’t work.
Does Enscape use a Revit setting to control Artificial Lighting visibility? or is there something else I’m missing? :confused: :S
Regards,
K
Hi Kevin,
it might be related to the distance from light to ground (or whatever it should hit). Right now, there is only a limited radius of influence, which depends on the light’s intensity. We will solve that issue in future releases.
The only option you could try is to increase the light’s intensity.
But that is just an assumption - usually the light’s distance is enough to see it. Could you post an image?
Regards
Thomas
