I have a problem with the last version of enscape, something is happen, in this part () in enscape 3.1 the lighting doesn’t works correctly, actually the light doesn’t light up, but when I try the version 2.7 () the light works
Welcome to our Forum!
Please be so kind as to re-upload/re-attach the pictures as we can’t access/see them yet - usually, it also helps to just copy-paste them directly into your post!
@Cazu1999 , thanks a lot - can you furthermore please reset your Visual Settings? More info on how to do that if you aren’t aware here! If that does not do the trick, please also definitely make sure that you are using the latest graphics card drivers available for your card, and acquire the drivers directly from either the AMD or NVIDIA homepage depending on your setup. Please get back to me if neither helps.
