Magnatizerr Gallery (updated with new renders on 03/11/09)
Here is my gallery - all comments and criticism are welcome.
Updated: 30/10/09
(Image 1)
I’ve started to go through old projects and looking for products to test my V4R abilities so here’s another attempt - All completed with V4R apart from a small amount of work in PS. Again, and C&C are most welcome.
(Image 2)
Updated: 21/06/06
Another old project from last year - playing around with a white product on a light background (an Air freshener for AirWick)
(Image 3)
Updated: 27/06/06
Diamond Ring on light coloured background - updated with ‘brighter’ gold material as suggested by Micha
(Image 4)
Updated: 04/07/06 - MP3 player - My first attempt at using the the ‘emissive layer’ (used on screen, button arrows and ear plug blue ring).
(Image 5 and 5a)
Updated: 30/11/06 - It’s a while since I’ve updated so I thought I’d post a few more images up (Still learning!) C&C welcolme
(Image 6) - Personal travel air freshner
(Image 7) - Gas BBQ
Updated 28/09/07 - Not updated for a while so I thought I’d post some renders done over the past few months.
(Image 8 ) - Jug and tumble set
(Image 9) - Plastic moulded table and chairs
(Image 10) - Radio with Windows home server connection
Updated 16/06/09 - Not updated for a while so I thought I’d post some renders done over the past few months.
(Image 11) - 4D Baby Scaner
(Image 12) - Soap ink pens for bathtime play
(Image 13) - Soap Packaging
(Image 14) - Water rollers for water transportation
(Image 14) - Solar powered wireless speakers for the garden
(Image 15) - Concept for an underwater sub for tourist hire
(Image 16) - First test image using RhinoHair
Magnatizerr Gallery
Looks very fine. Good work. Sweet models. :slight_smile:
Here some small suggestions:
- I can see the mesh polygons at the yellow part, better you use finer mesh settings
- The gap motar looks reflective here. I would use a diffuse material and test a fine noise bump on it.
- Background: I would set the camera angle a little bit higher so that the cut between white background and tiles is not visible. Also, I think the dark reflection in the background is not necessary.
- Colors: I prefer a more warm look. I have test it: gamma curve correction - less blue, more red + more saturation. Additional a vignetting effect per free tool ptlens and a little bit more blur in the background. But I think, it’s a question of the personal taste and the monitor.
I would test an additional area light with warm color. Could be a good contrast to the cold white environment light.
- Special effects: water drops on the tiles and on the turtles. :wink:
- The tiles looks verfy perfect like plastic. Maybe you could use a light bump. Or are the edges to round? I’m not sure, but looks like plastic.
-Micha :wink:
Magnatizerr Gallery
Hi Micha
Thanks for the reply - the unit is a bath temperature alarm for children I designed last year - I thought it would be a good model to test.
I will look to try some of your thoughts over the weekend?! I will however probably keep the ‘coldness’ of the image as I wanted it to look as if it were in a bathroom?!
Magnatizerr Gallery
If I think on children, than I feel “warm”. In my bathroom is window with blue light and a light bulb that spend warm light. You could use the cold environment and an additional warm light. A cold-warm contrast could give a nice attraction for the eyes and could give a subtle color variation at the gaps. Maybe as subtle fill light from the right side.
I forget to say, the display looks phantastic real. An idea: if it show 37.7?, than it must be wet or is the room so hot? :wink:
Magnatizerr Gallery
I’ll try the warm light fill.
Re: the display - I used an old technique from my 3D max days - create the graphic ie. 37.7 and place it just above the LCD screen surface but underneath the ‘lens’ surface. This creates a shadow under the numbers.
Agreed - may be I will put some water droplets in!! :lol:
Magnatizerr Gallery
Updated image moved to top post
Magnatizerr Gallery
Are that bump-maps (main tile) on the floor surface?
Magnatizerr Gallery
… the water drops looks fine. :slight_smile: Also the fine bump is nice.
I have observe the tiles in my bath. The corners are more sharp and the motar looks rough. :wink:
Magnatizerr Gallery
Hi Kreten - The bump is on the tile surface. I only applied the bump to the tiles in the foreground to keep the render time down. Tiles at the back are just high gloss. Render time approx: 20min.
Magnatizerr Gallery
Thanx!
Magnatizerr Gallery
Glass image moved to top
Magnatizerr Gallery
Hi Magnatizerr
         Really like your latest render, the glasses look very real and the backdrop works well with the scene. I like the natural lighting you have used, how have you set your lights up. I cant seem to get that natural light in my renders at all.
Regards
Mark
Magnatizerr Gallery
Hi Mark O - Thanks for the response, I will say that the lighting did take some time to set, but the setup is quite simple really.
1. General GI (skylight) set @ ‘1’
2. Single ‘point light’ set @ 50 (with a very subtle light blue tint) to simulate sun
3. Single panel light set @ 2.5, in front of glasses to high light main target areas and show up texture in cloth.
Then I played around with the materials. Hope that helps
Magnatizerr Gallery
Nice scene. And an interesting classical render problem - liquid in glass.
One problem for me are the black areas in the glass. Maybe you could use more reflection/refraction bounces.
A good tutorial for this subject:
How did you model the liquid in the glass - offset surface or split of the glass?
Magnatizerr Gallery
Hi Micha - I’m already using a reflection/refraction bounce of 12, and every time I went higher it didn’t seem to effect the render? Any thoughts?
Re: the liquid - yep, offset surface, with a little modeling.
Magnatizerr Gallery
… did you set a full reflection environment or a background only?
Magnatizerr Gallery
I tried both but this rendering uses (mid grey) background only
Magnatizerr Gallery
Could be a problem for the internal reflection. Mid grey - could be to dark.
BUT … I have tested it here and got the same problem. I have forgotten to disable “double side”! Now t works fine. It’s the old pitfall. I miss a solution here. Again: I don’t understand why I must disable this option for glass.
Magnatizerr Gallery
Thanks Micha - I’ll check and try a re-render later this evening.
Magnatizerr Gallery
Updated on 21/06/06 with an old project of a battery powered Air freshener for AirWick. Looking at experimenting with a light coloured product on a light background.
