Kemal's Gallery
Hi Guys,
This is my first post. I hope you like it. C&C are welcome.
Rhino 5 + V-ray 2.0 + PS
Nice! I like it! My only think is the blanket. I believe it need a little bit of more work. Maybe a small bump to create texture and I believe that the falloff or fresnel color for the perpendicular area is to light. So in the border of the blanket you could see a lot of white/bright reflection. You could try to use a pinkish color or grayish color.
Overall, was a really nice job!
Thanks for reply. This was my first render after joined 5SRW course. I was a beginner when i rendered this room. I believe in that i can render a better scene now but i really need comments like yours. By the way i’ll weigh your words and render this scene again mate. Thank you again.
Hi again,
This is the second render posted by me. I am still learning from masters like Grant Warwick and Ciro Sannino. I hope l’ll be better in a few months. I hope you like it also. Comments are welcome.
Another nice render! just one comment, the glass base could be improved. When you are doing a close up to a glass object like that, you could add dispersion to get the color separation effect and you can also increase the Max Depth for the glass material to 10.
First of all thank you for your reply and interested in with my renders mate. Secondly, actually l know dispersion but l forgot to add :smile: I’ll render it with dispersion and add again. Thank you again :slight_smile:
Hi Guys,
l rendered this scene in two different light setups. First one has 3 rec light and almost whole area is bright. Second one has localized spotlights. Which is better? What can i do to make improve them? C&C are welcome. Thanks in advance
Hi
Here is an interior tutorial in our webpage: Chaos Docs
I think you could use the part where me mentioned the portal lights. Beside that, I think you could use an dome light with an HDRI close to the image that you have in the exterior for the illumination. Instead of spotlight, I would use IES for the ceiling lamps.
Hi Fernando,
Thank you for your advise. I’ll check tutorial and try that on my scene.
Hi guys,
This is for the first time i’ve tried anisotropic render. I’m not sure that i understood BRDF :smile:
I hope you recommend a nice tutorial for Rhino BRDF. Thanks in advance
Hi guys,
This is my last work. I hope you like it.
Hi again, here is like a desert…l feel lonely but keep going to upload projects..Is there anybody can here meeee? :smile:
I hope you like my new project. Black on black render with Rhino+V-ray
Part 1
Part 2
Hi Kemal,
I really like those,the only things I don’t like are the white reflections that you have in the first part of your post.If they are cause by your lights,tag them as invisible,and no reflections,that should help.
Again great job!
Renee
Thank you for your reply renee81 :slight_smile: maybe i can change it with a dome light + hdri.
yes ,you can do that,but I would try the first option before.
Ok l’ll try that also mate :slight_smile: thank you again for your interest.
I like it too! But I think you can improve the gold material. Seem to be too reflective and flat. I think you could add a little bit of glossiness. Another thing is that some of the geometry seem to have sharp edges. I think you could either fillet them or use the Rhino edge softening tool (ApplyEdgeSoftening).
Hi Fernando, thanks for positive feedbacks. That was a quick job i had to handle with. I did all in couple of hours. Normally i am the man of details and i never miss out things like this. Anyway i’ll improve it in a spare time. Thank you very much.
It is a pretty good job to be done in just a couple hours! Congrat! Keep posting!
