Material for tree leaves
Hi everyone,
I want ask how to make proper material for tree leaves using translucency slot because whatever I tried it seems doesnt good for leaves.
The geometry is single faces only
Thanks before :smiley:
ps. sorry for my poor english
post some of your images would be the best bet - renders and shader tree
diffuse map for diffuse, slightly brighter (maybe more yellow-ish?) map for translucency, little reflection, some glossiness, low fresnel IOR, probably bump map, experiment :smiley:
Hi, thanks for both of your answer :smiley:
I still experimenting with the material and I guess I already find why is my leaves material is broken. After finishing my test I will post the SS here.
Again, thank you :smiley:
