Same material, but one does not generate blades..
I corrected the problem by painting the opposite side of the grass, so below it, but still if its reverse, it gives me a hard time if I want to create a path through the grass with other materials, cause I have to paint it upside down..
@benjaminriendeau Try the 2.0.2.971 preview version. Grass on backsides was fixed in this version.
Looked it up and I am up to date.. So I don’t know still.
@benjaminriendeau If you send a project with this problem to we will take a look.
I also had a similar problem. My solution was to give to the plain certain thickness (push and pull tool + ctrl 1cm) - than it works without any problem.
@benjaminriendeau Could you share an image of this with the Monochrome style in SketchUp enabled, I feel like this is an issue with frontside/backside face direction, which is why what @Sidorenko points out, extruding a 3D form fixes the problem, by doing that you rectify the direction of the face of the geometry.
