Material scale mismatching problem
Hi
The material I am using is the Rhino 6 default custum material as you can see on the attached image.
However the matiral show to big on enscape but correctly on rhino render view…
Anyone who have the same issue?
Rhino 6
enscape ver 2.6.1
regards
I don’t know if this is the same thing, but I’ve had trouble with Rhino 6 extrusions. They show different material mapping on screen than in the renderings. Converting them (ConvertExtrusion) to regular (closed solid polysurfaces) fixes it.
I kind of resolve the problem by changing the material setting to mapping channel and adjusting the repeat numbers.
however I ve got new issues that the material orentation does not match between render view or rhino s and the enscape view…
We are also having this problem!
