Why doesn’t VFB2 in 3ds Max save the changes in Display Correction to the LDR image?
In SketchUp and Maya’s VFB2, Display Correction changes are saved in the LDR image.
Does the difference in behavior make sense in the application?
Confirmed 3dsMax 2022 with V-Ray 5.2
If you mean the Exposure adjustment in the Display Correction - actually Max is the correct one. As the caption suggests - that correction is for display only and should not be saved in files. Will make a note to fix that.
Yavor
Okay.
I understand that the 3ds Max version behaves correctly.
