Hi there,
i have a scene where i have to simulate an effect where fine smoke will be absorbed by an object.
i’ve try’d several ways and ended up to simulate the smoke coming out the object, and reversed the simulation in phoenix. wich turned out quite nice except the beginning of the simulation where i always have the “mushroom” look, wich looks ugly on reverse..
any ideas how to avoid this?
thanks and best regards
Jonas
Yes indeed, the mushroom is what fluids do - the forces that cause them to swirl and roll and look like fluids also cause these mushrooms to form. You could reduce the Fluidity option in the Dynamics rollout and it should reduce this mushroom effect as well. Also, in addition, you could try to break it up using a Turbulence node.
hey svetlin, thanks for the tips. do you mean to reduce the quality under fluidity? i allready have turbulence in the scene, changing this would affect the overall look of the movement.. it would be great if the turbulence field could be limited to an area for such cases. I’ve solved it for now by animating a geometry right over the emitter.
Hey,
You can limit the effect of Turbulence by using a Voxel/Particle Tuner. Here are two videos that show how it works:
ah wasn’t aware of that. I’ll look into it. thanks!
