We need a working phoenix for latest V-Ray 7 for Maya, update 2 DR2 - for Maya 2026.3
I get this error in Maya
// Error: file: c:/program files/Autodesk/Maya2026/scripts/others/pluginWin.mel line 316: Unable to dynamically load : O:/Global/Software/Phoenix/52402_Vray7_maya2026/maya_phoenix/plug-ins/phoenixfd.mll
// The specified module could not be found.
// Error: file: c:/program files/Autodesk/Maya2026/scripts/others/pluginWin.mel line 316: The specified module could not be found.
// (phoenixfd)
We managed to reproduce the error, and it seems related to the portable PhoenixFD installation in conjunction with the latest V-Ray for Maya release. Could you try installing PhoenixFD with the default installer to confirm? Don’t forget to remove the PhoenixFD-associated environment variables beforehand.
EDIT: We found a quick and easy workaround:
Add this to the PATH environment variable in the Windows env variables: PATH = D:\phoenix_builds\my_version\maya_root\bin\
Or if you are using a .bat file: set PATH=D:\phoenix_builds\my_version\maya_root\bin;%PATH%
Tested this and it seems to work as expected. Tell me how it goes on your end.
