Phoenix Particles to Particle Flow
is there a way to bring the Phoenix FD flip solver particles into Particle Flow?
It would be great if I could render these Particles as shaded solid objects.
Or is it possible to render them with PHXFoam as solid objects? When I try it they are either transparent or white.
currently you can’t transfer the phoenix particles into particle flow particles, but if you just need to render the particles as spheres with material you can use the vray metaballs.
