Portal function not stopping with HTC VIVE
hi
i have just installed the latest alpha version, and i’m experience some issues with the portal function using HTC VIVE.
when i point at a position and presses and releases the button, it’s like encape does not stop this funktion, so im ported to where ever i point the ‘laser’.
Jorgensen
Hi Jorgensen,
we’re sorry to hear you’re having difficulties with Enscape.
Are you using Enscape for Revit or SketchUp?
Does the behavior still occur after a restart of Revit/SketchUp?
hi jonathan
sorry for my late reply - i thought that i get mails when i watch threads.
i’m using revit, and the problem persist. when i press the portal button, the ‘laser’ keeps staying on and move all over the place - i need to press ones more to ‘release’ it. never had this issue before.
the versions i use can be seen in the attached file.
jorgensen
Hi Jorgensen,
you can activate notifications in your account settings.
I would recommend you to downgrade to our latest stable version at first.
We will check this issue and will try to resolve it as fast as possible.
i will try downgrading.
i have just tried the stable version, and i have the same issue.
is it somehow possible to switch the two controllers so i can test if there is something wrong with the controller?
thanks
jorgensen
or is it possible to download older versions?
i have just testet in sketchup, and it gives me the same issue, but i guess that’ s obvious.
this is quite a problem for me as i have a presentation on monday.
jorgensen
i have just testet the controllers in both “the lab” and in unreal engine - no problems here - i can grab and release objects.
jorgensen
@Jorgensen we’ve found the source of this issue and fixed it in our latest stable version 1.9.1 for Revit.
thanks for fixing this issue.
jorgensen
