Running on HTC Vive - Input reversal
I run Enscape almost exclusively as a VR viewer. In recent Alphas the user input of head rotation and controllers have become reversed. (Turn my head right and the camera looks left.)
Is there a setting I have screwed up or something wrong with my computer?
you could try to press the “reset all” button in the settings to see if it helps.
Hi Alex,
it’s a already known issue of the latest alpha version.
We are working on it to solve it as fast as possible.
I would recommend you to downgrade to the latest stable version of Enscape (1.9.1).
hi jonathan
where do i download the 1.9.1 version - is that the same as the 1.9, on the download page?
and if i install this version - does that impact the newly fixed teleportation issue in sketchup?
thanks
jorgensen
Hi Jorgensen,
you can use the latest available stable version on the download page, should be 1.9.3.5.
The Update of Enscape for Revit does not impact Enscape for SketchUp.
So the teleportation stays fixed in SketchUp :wink:
Please notify me when you have this corrected in the alphas.
Thanks,
hi
running the lasted preview version, and it seems that motions are inverted when using htc vive.
i know this has been an issue before - but this should be a high priority fix, as it makes our use of enscape absolute impossible - or have i overlooked something?
jorgensen
Hi @Jorgensen_dk please update to our stable version 1.9.3.
The Bug is still contained in the current alpha as its still the same alpha.
It will be fixed in the next alpha.
