Postshot 3DGS to corona
I created a gaussian splat using postshot and exported as PLY. But nothing loads on corona. Tried scaling up, scaling down, every single orientation etc. Only the stats say something is there, but that is it. I do not know if this is a corona issue or a postshot export issue, any idea?
Based on the really tiny bounding box, it is just really really small (at least compared to the grid) - you may have to scale up way more than you are expecting! Don’t forget the scene can be sent to us via ticket at https://support.chaos.com/hc/en-us/requests/new then we can take a look directly.
Also welcome to the new forums!
I believe the issue was with postshot installation. Re-installed it and now it exported a working file.
From postshot support: “there has been a compatibility issue with PLY files in older Vray
versions. However, this specific issue was resolved in Vray v7.20.00.
If you are not using the latest version of Vray (or Corona), please try
upgrading to the latest version first.”
