Gaussian Splats not showing in viewport or render (Corona 14.1 + 3ds Max 2026)
Hi everyone,
I’m having an issue with Gaussian Splats in Chaos Corona and I can’t get the model to display after import.
I followed the exact steps from the official Corona Archviz YouTube tutorial and the Chaos blog tutorial for Gaussian Splats, but it still doesn’t work.
My workflow:
  • captured footage/photos
  • generated Gaussian Splats in Postshot
  • exported as .ply
  • in 3ds Max:
    Create → Geometry → Corona → CGaussianSplats
  • loaded the .ply file
Problem:
  • after import, nothing appears in the viewport or in the render
  • the object does appear in Scene Explorer
  • I already tried:
    • Zoom Extents (Z)
    • scaling 0.01 / 100 / 1000
    • rotating X 90°
    • Flip Y/Z
    • disabling viewport clipping
    • turning ACES OT off
    • testing in a completely new empty scene
  • Corona is set as the active renderer
Software versions:
  • Corona Renderer 14.1
  • 3ds Max 2026
Postshot export settings:
  • PLY Binary
  • Spherical Harmonics ON
I also followed the exact official workflow from https://www.youtube.com/watch?v=5h-vs_WvNow&t=117s :
Geometry → Corona → CGaussianSplats → load .PLY → adjust flip/scale
Has anyone experienced the same issue?
Could this be a compatibility problem with the PLY format exported from Postshot, or maybe a known issue with Corona 14.1 + 3ds Max 2026?
Thanks :slightly_smiling_face:
There was another report of similar case recently. I believe the solution was re-install postshot. You can read more details here: Postshot 3DGS to corona
Also please try using Corona 15 as we have this item in the changelog:
Fixed loading of certain .ply gaussian splat files.
