Revit crash when open Enscape
I have a problem.
When i open enscape in Revit, it closes.
Thank you
Not enough information. Please be more specific. Were you able to use Enscape before? Enscape version? Hardware? What is closing? Enscape? Revit?
I have likely the same issue with Revit 2020 and Nvidia 2060 RTX. After deactivating RTX features in Enscape settings a project loads ok. I am afraid there is some drivers’ issues. On the other machine there is no RTX video card, but it crashes while working with Enscape materials quite often.
We had similar issues until we updated our drivers (we have Nvidia GeForce RTX 2070 Super), we updated direct from the Nvidia website (as recommended by Enscape). New drivers with specific support for Enscape 3.1 were made available by Nvidia last week via their website..
Prior to the update the option to enable DLSS in Enscape was unavailable.
Now updated all seems to be working fine, with a marked performance improvement in Enscape with DLSS activated.
Sounds good, I did update right after the new Enscape release 3.1 and it didn’t help, but will try it again.
Do you mean you went around typical Nvidia Geforce Experience and found the driver instantly in their download area?
We went direct to the Nvidia website and searched for the latest drivers. you will need to ensure you download the correct driver for you particular graphics card (or ideally get your IT guys to do it for you).
We have Nvidia GeForce RTX 2070 Super and after update are running driver version 471.41 (but as I say you will need to ensure you get the correct driver for your particular card).
Good luck, and hopefully this will help.
Computer:
LENOVO_MT_20QT_BU_Think_FM_ThinkPad P1 Gen 2
Procesador Intel(R) Core™ i7-9750H CPU @ 2.60GHz, 2592 Mhz, 6 procesadores principales, 12 procesadores lógicos
RAM: 16GB
I use Revit 2022, 2021, 2020, 2019.
last Enscape version. I also tried with older versions.
NVIDIA Quadro T1000 (Last drivers)
Thank you
Thanks!
Which type did you choose - Game Ready or Studio?
Hi @fromani
In such cases, please send in a feedback report including the log files as well via the Enscape Feedback Button so we get more information.
You can add a link to this thread in the description so we can also keep everyone updated here.
Finally I solved my issue following this instructions:
https://enscape3d.com/community/blog/knowledgebase/multi-gpu-issues/
I’m having Enscape crash revit when I add materials via material editor. I add the colour, then the displacement map then it does the old critical error do you want to save a recovery file. I’m only working on a library/template file so it’s not processing large amount of information. I have the latest studio drivers on an RTX 2060 as well.
Thank you for any assistance you can provide.
Hi @scottyvalentine
In case you haven’t done so already, please send in a feedback report including the log files as well via the Enscape Feedback Button so we get more information.
Please also add a link to this thread in the description for context.
