We are having multiple users in our business who’s Enscape and Revit freezes upon opening up Enscape in Revit.
This issue does not affect other apps like Rhino or Sketchup.
The troubleshooting I have tried so far with this are:
clean uninstalling Enscape before reinstalling Enscape
updating GeForce RTX 4070 Laptop GPU drivers
installing/repairing MS Visual redistributables
different versions of Enscape including 4.7 the latest
changing Enscape graphics settings
recreated user profile
disabled all other addins in Revit
tried on a different laptop
tried different user on different laptop
created userPre.cfg in ‘C:\Users%username%\AppData\Roaming\Enscape’ file containing “r_vkDeviceSelectionOverride 1” or “r_vkDeviceSelectionOverride 0” or “r_giNvDenoising, 0”
clean out %localappdata%\Enscape\Logs and clean out the cache %AppData%\Enscape\Data\Textures and try the problematic model
The only that had any success was the last one, which was confusing as clean uninstalling Enscape as well as recreating the user profile would have deleted those folders so not sure why that fixed one of the user’s issue. However, it only worked once and we still have numerous people with this issue.
We also fixed another user with the issue by reimaging their laptop but it would be preferable not to do that for every user.
We also tried opening sample Revit models but it would only work on iterations of Revit they weren’t actively or recently using. Any user affected by this issue could not open any cloud models.
I have attached the latest log files for one of the users with this issue. Although the Enscape version is 4.2 in the logs, they did at first have 4.7 installed and was still having issues.
We will try installing 4.8 later today and see if that resolves it though, but any ideas on what is causing this issue would be greatly appreciated, thanks.
Enscape.RendererHost_2025-06-25_14-57-17_27532.log (4.6 KB)
EnscapeRevitPlugin_2025-06-25_14-53-32_23352.log (4.43 KB)
enscape_2025.06.25_15-00-35.log (18.6 KB)
